tach
tiny tach has a desiel tach that bolts to one fuel line from pump to cylinder. about 90 to 100 usd with shipping. the order form lets them know what engine you are using it one they will make sure you get what you need.
again taller gearing will work to a point I have a set up to adjust is to the the rpm of 2400 and did not have the guts to get out of 2nd gear.
