Old 06-21-2012, 03:14 PM   #6 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by ksa8907 View Post
For less stress on components you would want to switch the ground, electrical current actually "flows" from negative to positive.
But since the ecm is probably on a relay that switches ground, you should be ok. Be sure to check the underhood pdc for relays.
Not true on any ECM made in the last 20 years. ECMs always have constant +12V and ground with a "wake up" +12V signal from the keyswitch.
Dave, your plan should work great. Put an interrupt in the ECM keyswitch signal wire and the BCM will continue to count miles. Than all your problems will be solved!
