You should consider a rear Kammback for the car. I messed around with different front end blocks on my Sentra and found that there was little difference between making the front completely smooth and simply blocking the front. I have a coworker who drives a VW Transporter and he saw a huge improvement from doing a Kammback. Boxy vehicles are fine so long as you can fix the airflow at the back.
