Old 06-23-2012, 04:38 PM   #46 (permalink)
aerohead
plywood
Originally Posted by Sporty Modder View Post
Thankyou aerohead, that helps with my decision. I think I will build this wing upswept to the template line but not past. I also am thinking about1/4" plywood, with fiberglass resin painted to match the car. And some aluminum supports
If you can splurge,try and score some marine plywood.It is extremely dimensionally stable and won't warp on you over time.Ever! The stiffness will help too, so you won't have to do a bunch of reinforcements.
Vorticity on top of the foil will induce it to 'dance' so the stiffness is a welcome thing.
