Old 06-23-2012, 04:45 PM   #307 (permalink)
Cobb
I had Jack tell me the diodes are the weak point and if I upgrade those I could push more than 17 amps without causing the magic smoke to leak out.
From what I have read and experience is that the mo amps it pushes the mo mpg you get. I caught mines during the initial testing of MO POWER to see how much I could push for mpg before triggering an IMA fault. Seems once I am above 40 mph or have the eld on by way of an electrical load the sky was the limit. I achieved 103 mpg with extended use of ev mode hypermiling and with use of cc and aero mods managed in the mid 90s on my way to work on i95.
Anyway, let me ask you this. How do I get the sg2 to read anything other than the basic stuff of a hybrid? Ive sent mines into have it upgraded and tries countless programing from the manual, website and the prius chat website with no luck. I had one guy tell me I need the PID from Honda to read any of the hybrid data like the Prius will display, another guy said its onthe K lead of the odb2 port and needed a special reader with matching software as the sg2 doesnt connector to those leads on the odb2 plug.
