Old 06-23-2012, 06:40 PM   #81 (permalink)
bnmorgan
16 Ferret Circus
bnmorgan's Avatar
GrumblyDavidson - '00 Harley Davidson Road King FLHRP-I
90 day: 38.37 mpg (US)
Golf - '04 Volkswagen Golf GL-TDI
90 day: 38.29 mpg (US)
Years ago we talked about this,but maybe at MaxMPG which is now defunct.
In 1990,at World of Speed,a guy was there,who I believe had just received a MS in aeronautical engineering.He had a streamliner which had a sphere mounted on a shaft which 'preceded' the streamliner's nose.
The premise was that the streamliner would ride within the turbulent wake of the sphere kinda like a rocket-powered torpedo riding within some of it's own exhaust shunted out the nose,or a Russian ice-breaker with 'bubbler.'
I have no record that the bulb was a success.
It's possible that it was too small,and already embedded within the Prandtl surface of discontinuity,hidden from the source-flow.Don't know.
It's certainly possible to do such a thing,but with any crosswind component,it would lose performance,as the vehicle would no longer be occulted by the wake.
The other thing is that you're looking at at least a double-deformation of the forebody flow field and most messengers publish that air should make only a single pass over a structure with zero circulation,and zero separation.The bulb concept would kinda violate the rulebook.
There is something similar called aerospike (not the rocket engine) that is used on some missile systems, which is a section of a sphere (dish?) on an extended pole at the nose of the craft. I've seen them used on sub-launched missiles to create a cavitation bubble that the missile flies thru until it breeches the surface, and have seen them also on atmospheric launched missiles, presumably for the same concept of pre-punching the hole in the air with a smaller frontal area and then letting the bigger body fly through the expanding cone of cavitated air created. if it could be made retractable, it could be worth a try in automotives.
the e30 is dead
The Following User Says Thank You to bnmorgan For This Useful Post:
aerohead (07-31-2020)
