Old 06-24-2012, 06:47 AM   #83 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by bnmorgan View Post
There is something similar called aerospike (not the rocket engine) that is used on some missile systems, which is a section of a sphere (dish?) on an extended pole at the nose of the craft.
presumably for the same concept of pre-punching the hole in the air with a smaller frontal area and then letting the bigger body fly through the expanding cone of cavitated air created.
Something similar is done on the Russian K36 ejection seat to protect the pilot from extreme windblast during high speed ejections : a pole pops up at the front of the seat.
Those are all high speed appliances though.
Have a look at the Mach numbers for the light areas in the graph.
Even the ones in water are for - relatively - high speeds, as that's in a far thicker medium.
The Following User Says Thank You to euromodder For This Useful Post:
aerohead (07-31-2020)
