Old 06-25-2012, 10:54 AM   #71 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by Varn View Post
If it isnt the flame front then surly it is something else. Probably run away heat.
In a spark ignited engine, the combustion process is limited by flame speed because the flame is propogating through a premixed miture (limited by chemistry). In a diesel, the combustion process is limited by the mixing process--the air needs to get to the fuel before it can burn (limited by fluid motion). At some point it just can't mix fast enough to burn all the fuel. That's why you can't typically spin a diesel as fast as a gasser.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following User Says Thank You to Diesel_Dave For This Useful Post:
Varn (08-09-2012)
