After doing some more business travel, I got the chance recently to resume work on my bike. During testing I found that the fairing around the front wheel was too flexible so I added more stiffening elements to framework. I refueled yesterday for my first full tank with the dustbin styled front end and got 104 mpg. I've also found that the bike moves through the air with noticely less throttle and that I can use top gear more with much less downshifting. I still need to ensure that I have sufficient cooling air flow and to enclose the opening around the headlight. I also need more roadtesting to ensure that the dustbin front end is durable enough for the long trip to Ohio.
