Old 06-25-2012, 05:20 PM   #7 (permalink)
smokey442
Here's my thought. Make cylinder 1+4 into the air expander. Run cylinders 2+3 run in the conventional manner. Use exhaust valve as the air inlet and use 10-15% cutoff. Intake valve now becomes air exhaust. This requires custom ground camshaft with two lobes per position. Use an a/c compressor to replenish your air supply.
