Old 06-25-2012, 08:39 PM   #309 (permalink)
Cobb
Yes, Ive spent a lot of time pressing those 5 buttons setting up x guages, both before and after my sg2 was updated at their HQ. Seems the only one that works is the HP one and its accuracy is subjective as is, not to mention I get power from the IMA system. Still interesting to see between 3-6 hp to maintain45-55 mph.
Have you considering getting a battery pack to put between your porius pack and the enginer system? I had an idea to get another honda pack, hook up the blower to run continious to keep it cool and use a set of diodes to keep power from going into it from the IMA system. This way the PHEV converter has a buffer to help the high drain of ev mode.
Id contact Enginer if I were you, I heard something about 100 volts and 40 amps earlier today.
Maybe as soon as I can post attachments Ill do a post and youtube video of my install?
