I have'nt done anything yet, been busy. But i have been thinking about doing this EOC to work automatically.
What are your thoughts for this?
-Get VSS throught Hz-to-V converter(LM2917?)
-Get VSS throught comparator(with hysteresis)
-Interrupt switch between comparator and FET(gas pedal)
-Output to FET that switches camsensor.
I thought that would be the best circuit for this, as it would keep the RPM at engine idle if speed drops enough, and when you press the gas pedal, it does nothing.
And of course whole circuit can be switched off
