Old 06-26-2012, 10:41 AM   #311 (permalink)
Daox
Originally Posted by Cobb View Post
Have you considering getting a battery pack to put between your porius pack and the enginer system? I had an idea to get another honda pack, hook up the blower to run continious to keep it cool and use a set of diodes to keep power from going into it from the IMA system. This way the PHEV converter has a buffer to help the high drain of ev mode.
Yes, the thought has occured to me. I will likely never bother with it though. All of the places that I can get to while staying in EV mode I can get to as is. Some of them push me to the limie, but the frequency with which I go to those places isn't that often. So, a mod simply wouldn't be worth my time and effort. I think I'd be better off doing some more aeromods or something.
Id contact Enginer if I were you, I heard something about 100 volts and 40 amps earlier today.
I'm not sure what you are talking about.
Maybe as soon as I can post attachments Ill do a post and youtube video of my install?
You should be able to post links and attachments. I believe its just the first 10 posts that are restricted.
