Originally Posted by Cobb
I think in its oem un fooled around with design most diesels are safe in that regards. I have seen a youtube video where an old diesel seeked an alternative fuel source (ether and crank case oil) it ran away and spun a few bearings til someone choked it off, but as a newbie I cant post it here.
Its my understanding most engines have a sweet spot and really the lower of an rpms you can dial it in the more power and efficiency you will have. I heard back on my shop days inthe mid90s that it took 75 hp alone to spin a tradational v8 push rod lifter/cam shaft over 5000 rpms.
A diesel runaway is a pretty violent event. There are indeed a few good videos on YouTube.
1990 Geo Tracker with Kubota D950 diesel (work in progress)
1993 Ford Festiva with Yanmar 2TNV70 diesel
2004 Jeep Wrangler Rubicon with Scangage
2008 Nissan Rogue S
"This is only temporary, unless it works"-Red Green
