are grill blocks an *areo* thing or a *WAI* thing ?
if Aero then i suggest trim to fit and angle the bottom back a wee bit , to smoothly as possible match the existing angles/slope of the fairing
At any rate during the heat of summer watch your engine/coolant temps closely .
even 5 more miles a gallon is not worth melting your engine down
good luck
