It is not the weld nut by itself, it will be the thin tin were it will be tack to. The material used to build the Prius body it is not of any heavy stock.
I have use these pen nuts in almost the same applications with very poor results.
A length of angle iron bolted through with reinforcement in the underside of the body is a much better option.
I used this method to hold the 240 Lb of extra batteries on the last 2 PHEV conversions and it's rock solid.
I'm including the first photo I could find, but tha same concept of attachment.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
