Originally Posted by niky
air filters sometimes cause the engine to lean out slightly, as the ECU is receiving more air than it thinks it's receiving.
Until 0.0000001 seconds later when the ECU sees the O2 sensor value change and makes a fuel trim correction, netting absolutely no A/F difference at all.
