Old 07-02-2012, 12:00 PM   #112 (permalink)
orbywan
Originally Posted by slowmover View Post
Nationally repeatable results on weight = CAT Scale Search
$10 approximately for first weigh, then $1 for each re-weigh that day. In setting up trailer hitch rigging we may run across the scale several times.
I think the site linked above has instructions on how to use their equipment. PM me with any questions if they don't. It is essentially a matter of having the different axles on each of the three pads.
An "empty" weight (adjusted) is with driver, full fuel, full fresh water and propane plus items always aboard. A "full" weight is with all passengers, gear, supplies, etc. That is the one where I'd do individual wheel position weights to look for FF-RR or side-side discrepancies to be able to dial in tire pressure: instead of an axle average, use the position with the highest weight (with respect to vehicle manufacturer instructions / pressure range).
Capriracer has instructions on his site about pressure rise measurements to dial things in. Load versus pressure is the mantra for trucks of any size.
Thanks slowmover, I'll find out what this thing weighs.
