Old 07-02-2012, 11:02 AM   #49 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
In my opinion, the notion that fuel-cutoff is the holy grail is one of the biggest falicies out there in hypermiling. While it is true that you're not using any fuel at the moment, the engine is providing a considerable drag on the vehicle (hence the term "engine braking"). That drag is going to slow your vehicle down and you're going to have to make up for it later. The ideal of course is engine off in neutral, but in some cases even idling in neutral is better than motoring with fuel-cutoff.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following User Says Thank You to Diesel_Dave For This Useful Post:
PaleMelanesian (07-02-2012)
