Maybe I am giving the tire store too much credit. VWs load range recommendation is 91, these tires are 89. Perhaps they were filled higher to compensate for that, as the maximum load for the tire is 1279 lb at 44 psi, and the GVWR is on the order of 3800lb.
I'm not coasting, I'm shifting slowly.
