Originally Posted by niky
Aren't planetary gears simply... one gear?
a planetary gear has a few gears:
1 sun gear-which is typically the drive gear
2 (or more) planet gears-which connect the sun to the planetary gear
1 planetary gear- which is a large ring that touches the planet gears.
So there is a tiny gear, surrounded by more similar sized gears, wrapped in a larger circle.
