Originally Posted by niky
But seriously, no one is debating the added hydrogen helps combustion. That's a given. The question in my mind is whether the extra steps required to release that hydrogen are worth it versus injecting the fluid you're making the hydrogen from (water) straight into the chamber with the appropriate delivery system.
My point is the fame that made that lot of SCAMMERS!.
With inefficient HHO "Generators" you need a LOT of Amps from Alternator!.
In my tests, I got the best fuel economy with 6.5Amps (is that a Lot?) on my 1.5L engine
In this topic I'll try to ignore skeptics without arguments (specially if they haven't tested a HHO System
Greetings since Colombia!
