Old 07-04-2012, 01:25 AM   #113 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Here is what I could find on your E4OD transmission:
What are the gear ratios of the E4OD Transmission?
1st = 2.71
2nd = 1.538
3rd = 1
4th = .712
Take a gander at those numbers and the OD ratio in the US gear and gear vendors OD auxiliary transmissions. In some cases you will run in 3rd in the ford and OD on the other.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
orbywan (07-04-2012)
