Originally Posted by skyking
Here is what I could find on your E4OD transmission:
What are the gear ratios of the E4OD Transmission?
1st = 2.71
2nd = 1.538
3rd = 1
4th = .712
Take a gander at those numbers and the OD ratio in the US gear and gear vendors OD auxiliary transmissions. In some cases you will run in 3rd in the ford and OD on the other.
Duh, it's been so long since I ran an additional overdrive I forgot about running in anything other than OD on the E40D. Slow or what? Did it tell you the final drive ratio when running in OD of the E40D? Thanks for the info.
