Old 07-05-2012, 04:23 AM   #61 (permalink)
JJJoseph
Originally Posted by mechman600 View Post
If I can offer some simple advice:
The engine you pulled out of your Honda is a stressed member, an integral part of the frame/chassis. Make sure you [very] solidly connect the two engines mounts back together when you are finished. A solid connection between the headset (upper engine mount) and swingarm base (rear engine mount) is mandatory, or your frame will snap like a twig and hurt someone.
I'd be very nervous about this. This is a 200lb motorcycle (without engine) carrying 400lbs of batteries & electrics? It could snap like a twig! I'd be worried about the tires being overloaded, too.
