Half way through this tank I unplugged the EGR actuation solenoid(N-18). I placed a 1200 ohm resistor into the plug end so the computer will see a load and not throw a CEL for absence of the solenoid. The only time I get a CEL is when the engine is cold, and I get on the throttle. If it's cold, and I baby the throttle until it is warmed up, I don't get a CEL. This is a premptive test mod to see if I notice any MPG increase with EGR deleted. If I notice an increase in MPG's(or other benefits)I will progress to a more complicated "Dynamic" EGR scheme.
 2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
