Originally Posted by ron
smart meters can be turned off by the co .and they are not just going to turn it back on in a few min.( imagine the amp draw to fire every thing at once.) they have a peek hr charge, for now its like 7am to 6pm for peek charge. and when they get enough people working around the peek hrs the computer will tell them so and then they will change the bar WATCH
You can buy used electric meters, I'm sure you can buy a used smart meter even, I'm sure that if you take one apart you will not find a switch that can shut off the 200amps that could be flowing through the meter, but instead you will find a shunt for measuring how many watts are being used that is why the switches that can be installed to shut down single devices only shut down a single device, the time of use meters don't shut down devices, they log electrical use and the the time of day.
