Old 07-08-2012, 02:51 PM   #7 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by OmwToGallifrey View Post
The a/c only takes power when it's in use, correct?
Removing the A/C belt will help increase your mileage but if you remove your A/C belt then you can't run the A/C every month or so like the owners manual recommends to keep everything lubed and to keep the seals from drying out so in the long run it will cost more on upkeep, it also takes fuel to haul around the extra weight of the A/C.
