Old 07-08-2012, 08:10 PM   #231 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I was going to make a new thread but decided to keep everything here. I wired in a voltmeter to my TCU on the control for the LR/CC solenoid. In first, reverse, and neutral I read 8-9the volts, every other gear is B+, converter lockup at cruising speed is between 10.4 and 11 volts. Should I assume I need to switch this wire to ground?
