brucepick:
The vent in the VX is located inside in the back rear drivers side, its a small louvered opening in the molded plastic wheel well covering.
In behind that is the flapper vent that flaps opens to under the rear bumper so when you slam the door the extra pressure has a place to go.
The solar panel has a controller thats used for the battery, but if you unplug the solar panel from the controller then plug in the fan, its all the power it can muster.. last time I checked it was 27 volts at 2 amps, tho it slows with any clouds or trees passing, the fan seems happy.
2000 Insight MT 106K Citrus A/C
