Old 07-09-2012, 12:06 AM   #10 (permalink)
TurnNBurn
Originally Posted by Ryland View Post
I'd have to look closer at the specs of both of those motors, but the first thing that jumps out at me is how long they both are and how heavy they both are, the more expensive higher output one is almost twice as long and getting close to twice as heavy too, at least I think I'm looking at the right specs... but the smaller and cheaper of those two motors is shorter then then even a golf cart motor, so while you might be able to get away with running it at a higher voltage if you force cool it, it's really hard to say, D&D along with other motor companies tend to be pretty good at telling you how far you can push their motors.
I never considered weight. I see what you mean. I'm looking at some other smaller motors like the mars ME series and they're about 35 lbs (compared to 51-62 lbs for the D&D). The Mars are also smaller.
Here's another example of the prices versus specs I need help with:
ME0913 - $820
3-Phase Permanent Magnet Brushless Motor
24 - 96 Volts
Efficiency of 92%
12 KW (180 amps DC) continuous @ 96 Volts
23 KW for 1 minute (600 amps DC) Peak @ 96 Volts
Peak Stall Torque of 90 Nm (66 ft)
Designed for long life. No brush maintenance.
8" OD, 7.17" long (w/o shaft)
7/8"x 1-5/8", 3/16" key shaft
35 Lbs
ME0201014201 - $425
24 - 72 Volts
Efficiency of 90%
90 amps continuous current at 48 VDC
7.9" OD, 5.8" long (w/o shaft)
22 Lbs
Can someone explain the differences in the two? There are some specs on the first motor that aren't listed on the second motor, such as "23 KW for 1 minute (600 amps DC) Peak @ 96 Volts"
