Old 07-09-2012, 01:28 AM   #12 (permalink)
TurnNBurn
Thanks for the info, that clears it up a bit. I've been searching some other forums and found some other bike builders and I've seen a few use the ME0913, one guy chose the ME1003.
I want to say I've settled on the ME0913, but I want some advice. Has anyone looked into the ME1003 versus the ME0913 on a previous build?
Here are the specs and prices for each:
ME0913 - $820
3-Phase Permanent Magnet Brushless Motor
24 - 96 Volts
Efficiency of 92%
12 KW (180 amps DC) continuous @ 96 Volts
23 KW for 1 minute (600 amps DC) Peak @ 96 Volts
Peak Stall Torque of 90 Nm (66 ft)
Designed for long life. No brush maintenance.
8" OD, 7.17" long (w/o shaft)
7/8"x 1-5/8", 3/16" key shaft
35 Lbs
Mars ME1003 - $625
The ME1003 has a double brush set capable of 11.5 KW (200 amps) continuous and 23 KW for 1 minute (400 amps) @ 72 Volts
Permanent Magnet
12 - 72 Volts
8" OD, 7.42" long (w/o shaft)
39 Lbs
Here's a link to the other thread I was reading
My #1 goal at this point is to pick out a motor so I can order it and get it mounted to the frame so I can begin fabricating brackets and painting the frame. The controller and everything will come later.
-edit-
Also, how are electric motors at freely spinning? If I'm letting off the throttle and coasting to a stop light, will the motor cause any resistance and slow me down?
