Old 07-10-2012, 02:48 PM   #22 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I took my old diesel and made it run cleaner.
Not sure if it makes more or less NOx with water injection
It should make less as the water vapor keeps peak temps down a bit and spreads the heat more evenly.
The steam also helps to reduce or clean out carbon deposits in the engine, which is also good.
Now I get nearly no smoke.
No smoke on a diesel means better combustion.
If you don't use that for increased performance, you should also see an improvement in FE.
