Originally Posted by amdown
Personaly I tend to shift between 1600-1800 RPM and my conclusions is that shifting early is better for greater MPG. The question is how do other forum members shift and drive their TDI for greater MPG?
That's OK.
VW TDis are good at shifting at low rpm.
If you want to go fast, shift at the point where the rpm drop to just above the rpm at which you get max. torque
Usually even that means shifting at only 2500 rpm
