Are you sure about the 30 hp at 65 MPH? My truck is larger than your car and it needs about 32 hp at that speed on a cold day, based on a coastdown test.
Time for some math......
30 hp X 0.746 = 22.4 Kw. From the second graph, 22.4 Kw at 2500 RPM puts the engine BSFC right at 210 grams / PS / hr. You should be at slightly less than half throttle, say about 16 to 18 inches Hg vacuum.
If you could add one more gear to the transmission to drop the RPM to about 1800 at 65 MPH, the BSFC would improve to 195. Steady state gas mileage would improve by 210 / 195 = 8%.
You can pass in either gear. If you pass at or near WOT, the BSFC decreases to 190 grams/PS/hr in either gear.
If you stay in top gear, the power increases from 22 Kw to 50 Kw. That should be plenty for most passing. The most efficient passing is with the least increase in speed because you then spend less time at partial throttle (300 BSFC or worse) to slow back down.
