Old 07-13-2012, 01:12 PM   #3 (permalink)
Howard_Woodard
New Saturn EcoModder
Josh's Car - '95 Saturn SL1 SL1
Linda's Car - '06 Toyota Highlander Limited 4WD-i
Send a message via ICQ to Howard_Woodard
Thanks. I'll re-post. In the meantime, you've raised an issue that could very well be related. I hooked up a TIS scanner the other day and it showed a low voltage fault. At the time I wasn't able to follow up on it but your comment makes me thing I should.
Is the charge level adjustable or is it a sign that my battery pack is just old and getting weaker?
