Old 07-14-2012, 08:10 AM   #9 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by Old Mechanic View Post
Sounds like a bad speed sensor if that model does not have a cable driven speedometer.
regards
Mech
If you mean a Vehicle Speed Sensor ( VSS ), I replaced that part already.
The transmission seems to work fine untill it warms up, then the speedometer and odometer both die.
Fluid level is fine and not burnt smelling. I tried replacing the filter to the transmission, but this generation of Civic does not have a serviceable filter for the transmission.
Should I start a dedicated thread ? Or if you feel up to it perhaps you can PM me OldMech.
You were helpful once before in the past when I needed advice on the car.
