Old 07-15-2012, 07:12 PM   #1 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Question Kill switch electrical questions
Disclaimer: I am not an electrician! Which is why I'm having trouble figuring out just how to go about installing a fuel injector kill switch on a 7th gen Civic. First, the schematic:
Unlike the 5th and 6th gen cars, it seems my 2005 has two FI relays (each marked "main," confusingly)--Relay 2 grounds through the fuel pump, and Relay 1 through the ECM? So, do I have to cut both of them or just one? Would cutting the ground from Relay 2 cause fuel pump issues when trying to start the car again? Would cutting the ground on just one relay even shut down all the injectors in the first place?
Aerospace Engineer
www.amateuraerodynamics.com
