Originally Posted by vt_eg
Hi, quick question on the injector wiring for my honda civic
instead of splicing into one of the actual injector wire (0volt), can I splice into one of the four injector wire on the ECU pinout?
any help is greatly appreciated. thanks in advance
Dont know about specific Honda but answer should be YES. It should be same wire, just closer to its source - signal comes from ECU to injector.
I had mpguino wired near to to ecu injector pin in Mitsubishi Eclipse.
Meelis
