Old 07-18-2012, 01:06 AM   #55 (permalink)
DieselFuelOnly
DieselFuelOnly's Avatar
CX-5 - '16 Mazda CX-5 Touring
90 day: 30.96 mpg (US)
Yet another prime example of an old time habit that won't die.
Sure, if you have just parked your semi hauling 50,000 lbs across the mountains, that engine has been working very hard and a cool down period is advisable. Likewise if you have just plowed 50 acres with your Steiger. Likewise if you have just pitted from going 180mph in a Le Mans race. But just in from puttering around on the street? I don't think so.
Very good points.
My old diesel Ram (with an EGT gauge) would cool right down even after just 1 or 2 down shifts while coasting, to under 300F. Only after a heavy tow did I actually have to idle a bit to get EGTs down.
I imagine starters are better now, but wouldn't a starter cranking on a diesel be working quite a bit harder with the higher compression it's fighting at first? I know they're more heavy duty, but just a thought. In your situation I would probably be killing it.
