Old 07-18-2012, 08:54 AM   #9 (permalink)
BBrown7888
Originally Posted by euromodder View Post
Welcome to ecomodder.
Does your car require premium fuel ?
Yes - It has an LS6 Corvette engine.
If not, try regular and see how much less MPG you get.
It probably won't be worth the price.
In theory by switching to regular my MPG's would go up since premium has more additives in it to keep the engine cleaner that means there is less physical gasoline per gallon of fuel.
It's a good car as a base for a high-MPG vehicle.
Another one is the original Honda Insight, though they are relatively expensive to buy.
I'm looking to spend less than $2,000 on a car and go from there.
If they ever had a lean-burn CRX, try to grab one, or swap the engine for a lean burn Honda engine
Is there an engine code for these? (B18, D16, ETc...)
