Old 07-18-2012, 02:15 PM   #5809 (permalink)
type2teach
Woohoo! First real test drive over 10mph and hit some hills to boot. Everything fine except....
I understand the text box and setting parameters and stuff, but I can't get the info to SAVE.
That box above the black box, with the values, is that supposed to change once I type in a change? I'm having trouble with my potbox.
The parameters on the controller are set at 517 max throttle, but my pot will only go up to 499. I tried to change this, (and save it) but I don't think anything really changed, at least not in that top right hand corner box. Also, my pot doesn't go all the way back to "0". I have a sticky accelerator cable or something, so when I take my foot off the accelerator, it goes down to 20 (or so says RTD), AND the motor continues to spin, albeit slowly.
I set the parameters for the min to 22, but it's obviously not working.
And yes, I saved that, too. The black data box says the info has been saved to the ee, but I'm not experiencing this when I drive.
Any thoughts?
And THANKS SO MUCH!
Joel in Philly
