12.66 is a full charge w/o any surface charge. But 12.4 is actually more like a 50% charge, that being said, 12.3 on a good battery may be enough to start, I would want to have the meter on to watch voltage while cranking as I suspect a bad battery given the recent heat, unless you know why your battery is discharged
