Last night I worked on the batteries. First, I cleaned the cells, their terminals, and connectors. A couple cells look really rough (scorched from heat) but they tested good so I'm using them. Next, I connected all the parallel sets. The strongest cell was connected in parallel with the weakest cell, next strongest with next weakest so on and so forth. This leaves me with a pretty closely balanced pack. My lowest parallel capacity is 64.1Ah and the strongest set is 65.5Ah. By doing this it maximizes the usable capacity of the battery pack.
