Old 07-19-2012, 03:00 PM   #16 (permalink)
examorph
Wow, so many replies and some very good information! Thank you, now, I have a new question, length vs height vs width?
I have changed some things around on the car to reduce the length of it by almost half! but it has added a bit to the width but the material used to compensate for the width is no where as near as much as the material saved on length, also I have took the advice the majority of you have given and covered the wheels up.
so in conclusion, is it worth increasing the height and width to compensate for the reduction in length or should I really not worry as much about length and try keep the car as slim and low down in height as possible?
Also, one last question, is there any disadvantages of allowing the airflow under the vehicle?
