Neutral gear? If it is in neutral it is not in gear. You will be fine as long as the car if running when rolling in neutral as the engine keeps trans fluid pumping. If the car is off trans fluid does not flow and then parts get hot and issues can start. RVs will flat tow cars that do not allow it by adding a transmission fluid pump to keep the parts that are moving with the wheels lubed.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
