Old 07-21-2012, 07:10 AM   #1017 (permalink)
touring21
Prius 5 - '20 Toyota Prius Standard
90 day: 63.6 mpg (US)
Hi everyone just finished my install on my Mitsubishi lancer
I was able to put the mpguino into the clock module and widen the slot and it is looking really good.
I have the injector wire direct from the injector and the vss signal from the back of the speedo.
I was able to use the connector on the back of the clock to do the connection so I can easily remove it if necessary.
My problem is that the mpg at idle looks high and the mpg seems to get lower the faster I go up to 70 mph and still continues to fall. Is there anything I can look for to fault find?
The distance seem to be fairly accurate. I have got the fuel aprroximately right but not done enough miles to get it accurate yet.
I bought a completed module from meelis.
Thanks
