Originally Posted by touring21
Hi everyone just finished my install on my Mitsubishi lancer
I was able to put the mpguino into the clock module and widen the slot and it is looking really good.
I have the injector wire direct from the injector and the vss signal from the back of the speedo.
I was able to use the connector on the back of the clock to do the connection so I can easily remove it if necessary.
My problem is that the mpg at idle looks high and the mpg seems to get lower the faster I go up to 70 mph and still continues to fall. Is there anything I can look for to fault find?
The distance seem to be fairly accurate. I have got the fuel aprroximately right but not done enough miles to get it accurate yet.
I bought a completed module from meelis.
Thanks
Hi, did you read documentation?
It is downloadable here:
MPGuino trip computer - User manual/Installation
InjType 0,1,2 – Injector type. If you press accellerator and in „Car sensors“ screen „Lh“ value is getting smaller, then change this value from 0 to 1 or from 1 to 0. If you press accellerator and this value is not changing almost at all, then maybe your car have „Peak and hold“ type injectors and you could try value 2.
Meelis
