Old 07-21-2012, 05:25 PM   #13 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Originally Posted by redyaris View Post
If you wanted to design a motorcycle engine for better fuel economy you would start with a long strock engine that did not need very high rpm to produce the power you needed, so that there is less rpm change with change in road speed, so that the engine stayed very close to its optimum rpm for FE most of the time...
You're basically summing up what a Harley Davidson engine is ...
Correct me if I am wrong but there is a direct link between :
the speed you require / the fuel you are using whatever your engine type is.
The link is in the losses.
Pumping loss if your throttle is opened less than 3/4
Friction losses inside the engine.
Thermal losses.
Aerodynamic losses that are to be overcome
Gear reduction that is required to match the speed you require.
I believe the optimal is an engine that hit posted speed limit with 3/4 of throttle in top speed with as low an rpm as feasible and as good an SCx as possible.
Ideally the "as low an rpm as possible" item is treated in such a way that you are not too far of peak torque (which is also an indication that you are close to the best engine efficiency) which ultimately requires smaller duration.
