And I figure I can just use the existing AC radiator and pipe the heat from the hot side to that in order to keep them cool.
If you can turn your existing AC radiator (you do really mean the condenser in front of the car radiator?) into a working heatpipe without changing its orientation so it is above your peltiers (for gravity return of the working fluid) then you are WAY smarter than anyone I have ever met... As for your question, the short answer is I don't know. The longer answer (question?) is how do you know that 300 watts of cooling will do anything for you? Where did you come up with that number?
